Dayton 1/3 HP General Purpose Motor,Split-Phase,1725 Nameplate RPM,Voltage 115,Frame 48Z Model: 6XH45
General Purpose Motor, Split-Phase, Open Dripproof, 1/3 HP, Nameplate RPM 1725, 48Z Frame, Voltage 115, 60 Hz, 1 Phase, 7.0 Full Load Amps, No. of Speeds 1, Motor Mounting Type Rigid Base, Motor Thermal Protection None, Ins. Class B, 1.15 Motor Service Factor, Ball Motor Bearings, Frame Material Rolled Steel, Max. Ambient Temp. 40 Degrees C, CW/CCW Motor Shaft Rotation, Overall Length 9-3/4 In., Motor Shaft Design Keyed
Dayton 1/3 HP General Purpose Motor,Split-Phase,1725 Nameplate RPM,Voltage 115,Frame 48Z Model: 6XH45 Review
If you want really good additional, you can try this Dayton 1/3 HP General Purpose Motor,Split-Phase,1725 Nameplate RPM,Voltage 115,Frame 48Z Model: 6XH45. It's unbelievable!
