Clover White Hot & Cold Water Cooler with White POU Plus Install Kit & Filter
Enjoy a refreshing oasis in your home or office. The Clover White Hot & Cold Water Cooler with White POU Plus Install Kit & Filter (D7A-WHIKF) flows smoothly for a thirst-quenching drink by just pressing your cup or bottle against the self-closing valves. This water cooler reliably chills and heats water to just the right temperature thanks to the adjustable thermostat. You'll enjoy the reliable filtration of the Pentak GS-10Ro inline water filter. The included install kit allows for direct connection to your water supply. It's even made to last with a UV-protected, high-density polyethylene cabinet in white with a one-piece construction for easy cleaning and maintenance. You can trust in the leak-resistant dual-floats valve system to minimize water inflow. Simple: Mounting right on the floor, this water cooler is ready to pump out water with a press of your cup or bottle against the self-closing valve Reliable: You can trust that this water cooler will provide water chilled or heated to just the right temperature thanks to an adjustable thermostat and reliably filtered with a Pentak GS-10Ro inline water filter Durable: It's even made to last with a UV-protected, high-density polyethylene cabinet with a one-piece construction for easy cleaning and maintenance
Clover White Hot & Cold Water Cooler with White POU Plus Install Kit & Filter Review
I ended up buying this product after I read great amount of reviews, but Clover White Hot & Cold Water Cooler with White POU Plus Install Kit & Filter is top.
